2012 Toyota Camry Hybrid Specifications
Discussion in 'New Automobile Specifications' started by xcel, Aug 23, 2011.
    2012 Toyota Camry Hybrid Pricing
    2012 Camry Hybrid LE - $25,900, a decrease of $1,150 compared to the 2011 model.
    2012 Camry Hybrid XLE - $27,400, a decrease of $800 compared to the 2011 model with the upgrade package.
    Delivery, processing and handling (DPH) fee - $760.
    2012 Toyota Camry Hybrid Engineering
    Displacement (cc): 2,494 cc.
    Engine HP @ rpm: 156 HP @ 5,700 RPM
    Torque (lb.-ft. @ rpm): 156 lb.-ft. @ 4,500 RPM
    Engine and Hybrid System HP: 200 HP
    Redline (rpm): TBA
    Bore and Stroke (in.): 3.54 x 3.86
    Compression Ratio: TBA
    Expansion Ratio: 12.5:1
    Valvetrain: DOHC 16-valve VVT-i
    Multi-Point Fuel Injection
    Drive-by-Wire Throttle System
    Front-Wheel Drive
    CARB Emissions Rating: Clean States: AT-PZEV
    Federal Emissions: Tier II/Bin 3
    HSD Electric Motor/Generator
    MG2 Traction Motor
    MAX Voltage: 650 V
    Power output: 140 HP@4,500 RPM
    Torque: 199 lb.-ft.@0 – 1,500 RPM
    MG1 Charging Motor
    Power output: TBA
    Torque: TBA
    HSD Power Storage
    Ni-MH
    Mass: 150 pounds
    Voltage: 244.8V
    Capacity: 1.6 kWh/6.5 Ah
    Transmission
    ECVT
    2012 Toyota Camry Hybrid Safety
    Front, Side, Side Curtains, Driver and Passenger Knee airbags =, and rear passenger side ari bags std. ABS, VSC, TRAC, BA, EBD, Smart Stop or Brake Override plus Hill Start Assist Control (HAC) is std.
    Driver and front passenger Whiplash-Injury Lessening (WIL) seats std.
    Emergency Locking Retractors (ELR) on driver’s belt, Automatic/Emergency Locking Retractors (ALR/ELR) on all passenger seatbelts std.
    Tire Pressure Monitor System (TPMS) std.
    High-voltage cut-off function std.
    Hold START/STOP button for 3 seconds while driving: Engine will stop, but steering will not lock.
    2012 Toyota Camry Hybrid Performance
    Acceleration 0-60 mph: 7.6 seconds
    Top speed: TBA mph
    2012 Toyota Camry Hybrid Body/Suspension/Chassis
    Unit-Body Construction
    MacPherson Strut Front Suspension w/ Stabilizer Bar
    Independent Dual Link Rear Suspension w/ Stabilizer Bar
    Stabilizer Bar (mm., front/rear): TBA mm/TBA mm
    Electric Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock (16" wheel/17" wheel): TBA/TBA
    Steering Ratio (16" wheel/17" wheel): TBA/TBA
    Turning Diameter, Curb-to-Curb (ft.): 36.7 ft.
    Power-Assisted Ventilated Front Disc/ Solid Rear Disc Brakes (in.): 11.65/11.06
    Wheels: All-Season Tires: P205/65 R16 (LE) or P215/55 R17 (XLE)
    Compact Spare Tire
    2012 Toyota Camry Hybrid Interior Measurements
    Headroom (in., front/rear): 38.8/38.1
    Legroom (in., front/rear): 41.6/38.9
    Shoulder Room (in., front/rear): 58.0/56.6
    Hiproom (in., front/rear): 54.5/54.5
    Cargo Volume (cu. ft.): 13.1
    Passenger Volume (cu. ft.): 102.7 (LE) – 101.3 (w/ moonroof)
    Seating Capacity: 5
    2012 Toyota Camry Hybrid Exterior Measurements
    Wheelbase (in.): 109.3
    Length (in.): 189.2
    Height (in.): 57.9
    Width (in.): 71.7
    Track LE - 16”//XLE - 17” wheels and tires (in., front/rear): 62.4/62.0//62.0/61.6
    Ground Clearance (in.): 6.1
    Curb Weight (lbs.): 3,417 (LE)/3,441 (XLE)
    Cd: 0.27
    2012 Toyota Camry Hybrid EPA Mileage Estimates/Capacities
    Preliminary EPA (City/Highway/Combined): 43/39/41 mpgUS (LE) and 41/38/40 mpgUS (XLE)
    Crankcase (qt.): TBA
    Coolant System (gal.): TBA
    Fuel (gal.): 17.0
    2012 Toyota Camry Hybrid Standard Exterior Features
    LE Hybrid
    • Projector-beam halogen headlamps with auto-off feature
    • Daytime Running Lights (DRL) with off mode
    • 16-inch steel wheels with full wheel covers and P205/65R16 tires
    • LED tail lamps and stop lamps
    • Color-keyed power outside mirrors
    • Hybrid Synergy Drive blue accent badges on trunk and fender
    • Variable intermittent windshield wipers
    • Rear window defogger with timer
    XLE Hybrid
    • 17-inch alloy wheels and P215/55R17 tires
    • Chrome Exhaust tip, trimmed fog lamps and trunk garnish
    • Heated outside mirrors
    2012 Toyota Camry Hybrid Standard Interior Features
    LE Hybrid
    • 2.2” Multi-information Display
    • Dual-zone auto climate control
    • Smart Key System with push button start
    • Optitron meters
    • Power door locks with anti-lockout feature
    • Power windows with auto up/down (driver’s side only)
    • Cruise control
    • Manual tilt/telescopic steering wheel with audio controls
    • 4 cupholders and 6 in-door bottle holders
    • Courtesy lamp
    • Maintenance indicator
    • Rear center headrest
    • Bluetooth® hands-free phone capability
    • One 12V auxiliary power outlet
    • Overhead console with map lights and sunglasses holder
    • Lockable illuminated glove box
    • Metallic tech-grained interior trim
    • 60/40 split fold-down rear seat
    • Fold down rear center armrest with dual cup holders
    • Illuminated entry
    • Manual day/night rearview mirror
    • Urethane steering wheel and shift knob
    • Six-way manual driver’s seat and four-way manual passenger seat
    XLE Hybrid
    • Eight-way power adjustable driver seat and four-way manual passenger seat
    • Auto-dimming EC mirror with compass
    • Rear air vents
    • Leather-wrapped steering wheel with integrated audio and Bluetooth® controls
    • Two 12V auxiliary power outlets
    2012 Toyota Camry Hybrid Standard Audi System
    LE
    AM/FM/CD Player w/ MP3/WMA Capability, Six Speakers, Aux Audio Jack & USB w/ iPod Connectivity, and BLU Logic hands-free system.
    XLE
    Display Audio - includes 6.1” touch screen, AM/FM CD player with MP3/WMA playback capability, 6 speakers, auxiliary audio jack, USB port with iPod connectivity and control, vehicle information, hands-free phone capability, phone book access and music streaming via Bluetooth® wireless technology
    2012 Toyota Camry Hybrid Options (XLE Hybrid Only)
    • Convenience Package: Includes Integrated Backup Camera, HomeLink Universal Transceiver, and Anti-Theft System with Alarm.
    • Leather Package: Includes Leather-Trimmed Ultrasuede Seats and Leather Door Trim with Integrated Armrests and seatback pockets, Multi-stage Heated Driver and Passenger Front Seats, and four-way Power Adjustable Front Passenger Seat.
    • Display Audio with Navigation and Entune - Includes 6.1-inch Touch Screen, AM/FM CD Player with MP3/WMA Playback Capability, six speakers, SiriusXM Satellite Radio (Includes 90-Day Trial Subscription to XM Select Package), HD Radio with iTunes Tagging, Auxiliary Audio Jack, USB Port with iPod Connectivity and Control, Vehicle Information, Hands-Free Phone Capability, Phonebook Access, Advanced Voice Recognition, Text-to-Speech with Programmed and Customizable Text Responses, and Music Streaming Via Bluetooth® Wireless Technology.
    • Display Audio with Navigation, Entune and JBL - Includes 6.1-inch Touch Screen, AM/FM CD Player with MP3/WMA Playback Capability, 10 JBL GreenEdge Speakers Including Subwoofer, Amplifier, SiriusXM Satellite Radio (Includes 90-Day Trial Subscription to XM Select Package), HD Radio™ with iTunes Tagging, Auxiliary Audio Jack, USB Port with iPod® Connectivity and Control, Vehicle Information, Hands-Free Phone Capability, Phonebook Access, Advanced Voice Recognition, Text-to-Speech with Programmed and Customizable Text Responses, and Music Streaming Via Bluetooth Wireless Technology.
    • Premium HDD Navigation with Entune and JBL - Includes 7-inch Touch Screen with Spilt-Screen functionality, AM/FM CD Player with MP3/WMA Playback Capability, 10 JBL GreenEdge Speakers Including Subwoofer Amplifier, SiriusXM Satellite Radio (Includes 90-Day Trial Subscription to XM Select Package); HD Radio with iTunes Tagging, Auxiliary Audio Jack, USB Port with iPod Connectivity and Control, Vehicle Information, Hands-Free Phone Capability, Phonebook Access, Advanced Voice Recognition, Text-to-Speech with Programmed and Customizable Text Responses, and Music Streaming Via Bluetooth Wireless Technology.
    • Safety Connect- includes Emergency Assistance, Stolen Vehicle Locator, Roadside Assistance and Automatic Collision Notification. Available by subscription. [Complimentary 1-year trial subscription]
    • Blind Spot Monitor
    • Power tilt/slide moonroof with rear personal lamp and dual illuminated visor vanity mirrors.
    2012 Toyota Camry Hybrid Available Colors
    • Attitude Black Metallic
    • Clearwater Blue Metallic
    • Cosmic Gray Mica
    • Cypress Pearl
    • Barcelona Red Metallic
    • Sandy Beach Metallic
    • Magnetic Gray Metallic
    • Classic Silver Metallic
    • Super White
    2012 Toyota Camry Hybrid Warranty
    • 3-year/36,000-mile Comprehensive
    • 5-year/60,000-mile Powertrain
    • 5-year/unlimited-mileage Corrosion Perforation
    • 8-year/100,000-mile Hybrid-related Component Coverage
    • Toyota Care – Complimentary maintenance plan with the purchase or lease of every new Toyota. For 2 years or 25,000 miles, whichever comes first, every new Toyota will be covered for all normal factory scheduled service, as well as 24/7 roadside assistance.
  2. seftonm
    One thing that surprised me, the Camry Hybrid's trunk volume beats that of the Sonata Hybrid even though the Sonata has the fancy lithium batteries. Is Toyota's packaging that much better or is lithium simply not much of an advantage over NiMH when it comes to space efficiency?
    Hi Mike:
    I have the preview about 2/3 complete and the reason for the improved trunk volume is they moved the all-new smaller inverter up front under the hood and moved the smaller pack forward to gain the extra 2.1 cu. ft. of cargo capacity over the 2011.
    Pretty ingenious of Toyota and the trunk is actually a usable 13.1 cu. ft. too!
    I have a lot more in the preview that is about 2/3 complete.
  4. Kacey Green
    Kacey Green Well-Known Member
    Li is a little smaller in the HCH3 over the HCHII, but like wayne points out, the whole electronic system needs to be taken into accont
  5. msirach
    A 2.1 sq.ft. gain would be an increase of 1.4 Ciminillo's for a total of 8.733 Ciminillo's it would hold!
