2011 Kia Optima Hybrid Specifications
Discussion in 'New Automobile Specifications' started by xcel, Jul 16, 2011.
    Pricing
    2011 Kia Optima Hybrid Manufacturer’s Suggested Retail Pricing
    Column1Column2Column3Column4
    ModelEngineTransmissionMSRP
    Optima Hybrid2.4L Hybrid I4Six-Speed A/T$26,500
    Optima Hybrid with Premium Technology Package2.4L Hybrid I4Six-Speed A/T$31,500
    Current Delivery and Handling: $750
    Engineering
    Engine Type: I-4
    Displacement (cc): 2,359
    Engine HP@rpm: 166@6,000
    Engine Torque (lb.-ft.@rpm): 154@4,250
    Bore and Stroke (in): 3.46” x 3.82”
    Compression Ratio: Atkinson Ratio of 13:1
    Valvetrain: DOHC CVVT (Continuously Variable Valve Timing)
    Multi-point fuel injection
    Hybrid Type: Full parallel
    Battery Type: Lithium Polymer
    Battery Capacity (kWh): 1.4
    Battery Output (kW): 30
    Battery Voltage (V): 270
    Battery Weight (lbs): 95.9
    Battery Capacity (Ah): 5.3
    EV Operation Limit: 62 mph with higher speeds capable downhill
    Hybrid Motor HP@rpm: 40.2@1,400 – 6,000
    Net HP@rpm: 206@6,000
    Hybrid Motor Torque (lb.-ft.@rpm): 151.2@0 - 1,400
    Net Torque (lb.-ft.@rpm): 195.4@4,250
    Front-Wheel Drive
    CARB Emissions Rating: SULEV-II
    Federal Emissions: Tier II/Bin3
    Transmission
    Gear Ratios of the 6-Speed Automatic Transmission:
    1st: 4.212
    2nd: 2.637
    3rd: 1.800
    4th: 1.386
    5th: 1.000
    6th: 0.772
    Final Drive: 3.320
    Reverse: 3.385
    RPM @ 60 mph (calculated):
    With P205/65R16 Tires: 1,950 rpm
    With P215/55R17 Tires: 1,980 rpm
    Body/Suspension/Chassis
    Unit-Body Construction
    Multi-link Rear Suspension
    Stabilizer Bar (front/rear): 24 mm/15 mm
    Electric Power Steering (EPS) steering column mounted, Rack-and-Pinion
    Steering Wheel Turns, Lock-to-Lock: 2.94
    Steering Ratio: 15.3:1
    Turning Diameter, Curb-to-Curb (ft.): 35.76
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.8/11.2
    Wheels:
    16 x 6.5-in. alloy wheel (Base Hybrid)
    17 x 6.5-in. alloy (Hybrid with Premium Technology Package)
    Low Rolling Resistance All-Season Tires:
    With P205/65R16 Tires (Base Hybrid)
    With 215/55R17 Tires (Hybrid with Premium Technology Package)
    Spare Tire: Inflator Kit std. – Spare optional
    Interior Measurements
    Headroom (in., front/rear): 40.0/37.6
    Legroom (in., front/rear): 45.5/34.7
    Shoulder Room (in., front/rear): 57.2/55.7
    Hiproom (in., front/rear): 54.7/54.5
    Cargo Volume (cu. ft.): 9.89
    Passenger Volume (cu. ft.): 102.17
    Seating Capacity: 5
    Exterior Measurements
    Wheelbase (in.): 110.0
    Length (in.): 190.7
    Height (in.): 57.0
    Width (in.): 72.1
    Track (in., front/rear):
    16-in. wheels - 63.0 in./63.0 in.
    17-in. wheels - 62.8 in./62.8 in.
    Ground Clearance (in.): 5.1
    Curb Weight (lbs.): 3,490
    Weight Distribution (%, front/rear): 59/41
    Cd: 0.26
    EPA Mileage Estimates/Capacities
    Hybrid (City/Highway/Combined mpgUS): 35/40/37
    Crankcase (qt.): 4.75
    AT transmission fluid (qt.): 6.87
    Coolant System (qt.)
    Engine: 7.15
    Hybrid Electronics: 2.4
    Fuel (gal.): 17.2
    Colors
    Exterior:
    Snow White Pearl
    Satin Metal
    Light Graphite
    Ebony Black
    Interior:
    Beige
    Black
    Warranty
    10-year/100,000-mile limited powertrain
    5-year/60,000-mile limited bumper to bumper basic
    5-year/100,000-mile anti-perforation
    5-year/60,000-mile roadside assistance
  2. bomber991
    bomber991 Well-Known Member
    Now that's an expensive Kia.
  3. Nevyn
    Nevyn Well-Known Member
    I drove one last week. :D It was nice. VERY aggressive on regen from the pedal, and would go EV mode like it was trying to singlehandedly save the planet.
    I liked it. A LOT.
