a nice counterpoint
Discussion in 'Events and Gatherings' started by hobbit, Jun 17, 2011.
  1. hobbit
    hobbit He who posts articles
    I spent much of the day carefully doing the overdue engine coolant
    change in the Prius, which ironically involves wasting quite a
    bit of fuel to run the engine up to hot and let it cool down, try
    to burp more air out of the system, repeat ... I think I've got
    most of it, but it's going to take another few days of monitoring
    and topping-up before it's really done. With all that extra
    plumbing for the heat-storage tank and valves whose state one is
    never quite sure of, one must be *very* patient with this thing.
    There will be an eventual writeup, but the topic has received
    pretty solid coverage on priuschat and I'm not even sure I was
    doing the right things
    So after popping by the Toyota place for more of those dumb
    little breakable plastic clips for the fender liners, I went to
    our local cruise-in. It's this fairly informal thing that just
    crowdsources itself in the back lot of a local restaurant every
    Thursday, and is fairly well-attended. The two [now] times I've
    gone with the Prius, I've always gotten quite a bit of interest
    and this time I threw together the rudiments of the roadtrip bed
    rig to show it off in "60mpg RV" mode. Slotted quietly in between
    two shiny fire-breathers and set up. Several passersby offered
    comments along the lines of "awesome" and wanted to know more about
    how hybrids work, how I can be at 160K with all original brake
    parts, etc. We can ignore the crusty old vet-with-a-vette from
    across the way who wandered over and started talking about how
    many japs he killed in a day, but I guess that's his version of
    american freedom. Anyway, it was an amusing way to spend some
    of a nice Thursday evening -- maybe the first really *nice* day
    we've had this year, maybe finally done with the winter that
    wouldn't quit.
    _H*
  2. Harold
    Harold Well-Known Member
    I think I will just let Toyota do my coolant change! Too damn risky , especially when the car has no temp. gauge. I have a SG on order for my HCH2 so is it a big deal to switch from car to car. I could at least monitor the temps. for awhile after changing the coolant. H
  3. Ophbalance
    @Al> Did you get in for your free coolant replacement pump yet? I'm assuming they replace the coolant at that point as well. At least, I hope they do.
  4. Harold
    I had my 06 free coolant pump replaced. Not sure if new coolant was added. Probably was though. That coolant is not part of the ICE coolant? H
  5. Ophbalance
    Ah right, wrong coolant. Sorry, my reading comprehension appears to be far from spot on today.
  6. hobbit
    Well, to answer that question anyway, I did my own inverter pump
    swap and coolant change at a little over 100k. Pump was cheap
    enough and the collective learning experience I could gain from
    doing it myself well worth the price of not getting it for free
    and having some dealership monkey screw up my car.
    It took a couple of days to finally burp the remainder of the
    air out of the engine coolant system, but it's done and so is the
    writeup -- part 5b of where all this is excruciatingly documented:
    _ http://techno-fandom.org/~hobbit/cars/maint100k/
    _H*
