2006 Ford Escape Hybrid FWD/AWD
Discussion in 'New Automobile Specifications' started by xcel, Mar 23, 2006.
    Engineering:
    Displacement (cc): 2,261 cc
    Horsepower @ rpm: 133 @ 6,000 rpm
    Horsepower Net @ rpm: 155 HP
    Torque (lb.-ft. @ rpm): 124 lbs.-ft. @ 4,250 rpm
    Bore and Stroke (mm): 87.5 x 94.0 mm
    Compression Ratio: 4.0:1 - 12.3:1
    Expansion Ratio: 12.3:1
    Valvetrain: DOHC 16-valve
    Sequential multi-port electronic
    Drive-by-Wire Throttle System
    Front-Wheel Drive
    CARB Emissions Rating: AT-PZEV
    Federal Emissions: Tier II/Bin4
    HSD Electric Motor/Generator:
    Power output: 94 HP @ 3000 - 5000 RPM (70 kw @ 5,000 rpm)
    Torque: 100 lb.-ft. @ 840 rpm
    HSD Power Storage:
    Ni-MH
    Voltage: 330V maximum
    Transmission:
    ECVT
    Body/Suspension/Chassis:
    Unit-Body Construction
    Multi-link independent Rear Suspension
    Stabilizer Bar (mm., front/rear): 20 mm/ mm
    Electric Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 3.7
    Steering Ratio: 19.1:1
    Turning Diameter, Curb-to-Curb (ft.): 37.7 ft.
    Power-Assisted Ventilated Front Disc/Rear Disc Brakes (in.): 11.9/11.9
    Wheels: All-Season Tires: P235/70R16
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 40.4/39.2
    Legroom (in., front/rear): 41.6/35.6
    Shoulder Room (in., front/rear): 56.3/55.9
    Hiproom (in., front/rear): 53.2/49.1
    Cargo Volume (cu. ft.): 27.6 cu. ft. (rear seat up)
    Passenger Volume (cu. ft.): 99 cu.ft.
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 103.2
    Length (in.): 174.9
    Height (in.): 69.9
    Width (in.): 70.1
    Track (in., front/rear): 61.1 / 60.4
    Curb Weight (lbs. MT/AT): 3,610/3,775
    Weight Distribution (%, front/rear): 56.4/43.6
    Cd: 0.404
    EPA (City/Highway): 36/31//33/29 mpg
    Crankcase (qt.): 4.5 quarts with filter
    Coolant System (qt.): 11.6 quarts
    Fuel (gal.): 15.0
    ___Gary sent me this FEH/MMH Torque curve for clean up and upload. Although not a perfect rendition, the rotation, brightness, contrast, and gamma adjustment cleaned it up pretty good.
    2005 - 2007 FEH/MMH RPM vs. Torque Curve
    ___Notice the slight flattening around 1,750 - 1,850 RPM and again at ~ 3,000 RPM? Gary pivots around that 1,800 RPM accel when it is clear to do so IIRC. I would park the accel rates of the FEH/MMH there too if it were me. 3K on the tach seems a bit much but for a full blown P&G with pack permissives allowing ICE-Off to EV via LGA - N - D in cooler temps, I would try it to see what happens there as well?
  3. GaryG
    GaryG Well-Known Member
    Thanks Wayne
    That was nice of you to clean the photo up also. Well, my secret is out now thanks to you.
    GaryG
