Scott with 1999 Honda Civic HX 5MT from Elkton, MD
Discussion in 'Start Your Journey Here' started by LinuxGold, Jul 10, 2010.
  1. FSUspectra
    I remember saying you had that and other items fixed. The chrome fitting is the muffler decoration tip? Did a weld break loose? I'm surprised Firestone did that muffler work... unless they had a bolt-on catback system? Not cool that it's not sitting right again, hopefully you'll get it fixed right! ;)
  2. LinuxGold
    LinuxGold Hypermile to the finest
    Yep, it is the muffler decoration tip. Hopefully they will get it fixed right this time!
  3. LinuxGold
    I will need to do 5 tanks, 200 miles interval of refills, checking my tank mpg, adjusting scangauge, my P&G techniques and shift timing.
  4. LinuxGold
    Per 1999 Honda Civic HX manual (recommended for best fuel economy):
    US: DX, EX, HX, Canada: DX, Si
    Column1Column2
    Shift upNormal acceleration
    1st to 2nd15 mph (24 km/h)
    2nd to 3rd27 mph (43 km/h)
    3rd to 4th39 mph (63 km/h)
    4th to 5th53 mph (85 km/h)
    Shift upCruise from acceleration
    1st to 2nd9 mph (14 km/h)
    2nd to 3rd20 mph (32 km/h)
    3rd to 4th33 mph (53 km/h)
    4th to 5th48 mph (77 km/h)
  5. PaleMelanesian
    Let's just say, their idea of economy is not the same as ours. ;)
    gears 1,2: as brief as possible.
    3rd: up to 25 mph max
    4th: 20 cruise, 25 min pulse, 40 max
    5th: 30 cruise, 35 min pulse, max = whatever your max speed is. :(
  6. Right Lane Cruiser
    My Insight is geared similarly to the HX I believe and my shift points are at:
    1-2 @ 8mph
    2-3 @ 17mph
    3-4 @ 24mph
    4-5 @ 31mph
    I have shorter gearing in the Elantra and shift 2-3mph earlier in that car.
    I do use 20mph deltas when I P&G, but usually only on the highway where it can all be done in top gear and really needs to be that wide to make up for the rapid slow downs while gliding. Most around town P&G is done in 4th gear in the Elantra, occasionally 3rd gear if the speeds line up properly. I shoot for single gear pulses with a top RPM around 2300. I like 15mph deltas for slower work, but I'll take larger deltas on occasion for stop sign to stop sign work.
    Cruising can happen a few mph slower in the Elantra but the Insight shift points above are already just above stumble.
    The Insight is a completely different animal when using P&G if you want to avoid hitting the pack. It also doesn't really have much extra torque past the LOD value that brings assist into the mix anyway.
  7. LinuxGold
    Analysis was done this morning (April 20, 2011)
    Column1Column2Column3Column4Column5
    MPHAndrewSeanAnalysispoints to try
    1-2brief8**brief
    2-3up to 25 max1715 mph @ 12k - 28 mph @ 18k15mph-25mph
    3-420 cruise, 25 min pulse, 40 max2425 mph @ 12k - 40 mph @ 20k25mph-35mph
    4-530 cruise, 35 min pulse, Infinite3140 mph @ 16k - 50 mph @ 18k35mph-50mph or to rpm BEFORE VTEC-E ends
    5th gear, 20 mph @ 737 rpm
    5th gear, 30 mph @ 11k rpm
    I REALLY REALLY need to know the TRIGGERS that END the VTEC-E's stage (economic mode)
  8. Right Lane Cruiser
    5th gear at 20mph is definitely too low. You might be running in Open Loop mode (dumping lots of fuel in to keep the cylinders from burning) if you pulse down in that range.
  9. LinuxGold
    That is probably why. I'll start pulsing at 30-35ish.
  10. LinuxGold
    Scenariosolutionstatus
    5th gear @ 20mph from stopchange to 35mph
    5th gear @ 30mph from uphillchange to 35mph
    Siphoning gas tankBuy new gas cap with keyDONE
    Possible engine problemFirestone to check car out
    Muffler misaligned (evidently)Have Firestone fix their mistake
    Delta of 25 @ 50 mph MAXReduce Delta to 15 @ 50 mph MAX
  11. Right Lane Cruiser
    Scott, I would still recommend dropping down a gear for pulses. Look for a top out at around 2300 RPM.
  12. LinuxGold
    MPHAndrewSeanAnalysis (4/20/11)points to try
    1-2brief8**brief
    Recommendationsdropping down a gear for pulses. Look for a top out at around 2300 RPM.
  13. LinuxGold
    *blows dust from this thread*
    First of all, let's update the latest records:
    To home commute 80.7/20.3 mi
    To work 78.2/23.8 mi
    Segment 121/.5 mi
    Tank 69.41/542.8 mi
    Now, next to my status:
    5th gear @ 20mph from stopchange to 35mph Do not use 5th gear until ABSOLUTELY necessary
    5th gear @ 30mph from uphillchange to 35mphUse 5th for DWL @ 70-75% at steep uphills
    Possible engine problemFirestone to check car outAborted
    Delta of 25 @ 50 mph MAXReduce Delta to 15 @ 50 mph MAXDelta variable up to 47 mph MAX @ 4th gear
    Recommendation & my latest shift patterns:
    1-2brief8**brief
    2-3up to 25 max1715 mph @ 12k - 28 mph @ 18kup to 20 max (25 @ uphills)
    3-420 cruise, 25 min pulse, 40 max2425 mph @ 12k - 40 mph @ 20k20-47mph
    4-530 cruise, 35 min pulse, Infinite3140 mph @ 16k - 50 mph @ 18kDo not use except for uphills DWL
    Recommendationsdropping down a gear for pulses. Look for a top out at around 2300 RPM.dropping down a gear for pulses, topped out around 2300 @ 47mph
  14. LinuxGold
    So far the current best of Civic HX
    To home 80.9/19.2
    Segment 121/.5 mi
    Tank 69.41/542.8 mi
  15. pitch4pd
    pitch4pd New Member
    A fellow MD hx'er here.
    Two cents on lean burn that I learned from this application Torque on my Android phone.
    Lean burn mode operates above 50-55mph from what I can tell.
    It will get out of lean burn mode if your vacuum drops below 3.6 mm/hg or above 22 (when you take your foot completely off the throttle it will bump you out of lean burn since your vacuum peaks).
    To get it into lean burn it likes to see a small steady load first, somewhere around 12mm/hg vacuum is normally where it will drop into lean burn mode, you will see your vacuum drop dramatically since you will need more throttle to compensate for lean burn mode. If you dropped out of lean burn due to your foot coming off the gas, it normally will jump back into leanburn within 5-10 seconds of "cruising"
    In lean burn mode your timing advance goes higher (more advance).
    That is all I have right now. Torque doesn't calculate MPG off of pulse width so it is not the best for MPG calculations when in lean burn, actually shows a 20% loss of mpg in lean burn so I know it is going off of air flow.
    If I had access to extended PID's I would have a book written by now on HX lean burn mode parameters but being a cheap butt I am; my 5 dollar android app and 25 dollar bluetooth obd2 connector is the most I am willing to spend to "play"
    any questions , feel free to shoot them to ccs507 (At) ptd . net
    My best mpg is 44 , best range is 495 miles. Biggest fill up 12.7 gallons. Longest time to get the engine to crank with the fuel gauge below F (poor poor fuel pump priming) is 15 long seconds!!, I have a CVT tranny so I am at a small disadvantage; I also refuse to cycle my engine on and off, I will pay the extra dollar a tank for my convenience of a running engine at a stoplight! I also lose mileage due to a 12" subwoofer and 600W amplifier.
    Cheers
    Charles
