Scott with 1999 Honda Civic HX 5MT from Elkton, MD
Discussion in 'Start Your Journey Here' started by LinuxGold, Jul 10, 2010.
  1. Right Lane Cruiser
    Scott, you didn't have to do that to calibrate the gauge. All that is required is a consistent driving style. Your car has variable lean burn modes just like my Insight -- driving with a heavy foot will knock it out of lean burn. Your gauge is likely now calibrated to an overall richer mixture so it will read low.
    With good driving technique you should be in lean burn for a good portion of your driving -- it will take a few tanks to get it locked in consistently and even then it may vary depending on your mix of driving for that tank. For example, P&G will give different results than steady state driving so tanks that are predominately city driving could differ from tanks which are predominately highway cruising using DWL. I use P&G in the Elantra everywhere and the calibration has been good no matter what mix I drive because of this.
    Good luck and enjoy your new ScanGauge!
  2. LinuxGold
    LinuxGold Hypermile to the finest
    Thanks Sean.
    It is interested to see how HARD it is to BREAK my hypermiling habit. =)
  3. LinuxGold
    Went to Firestone last Saturday, two tires went bad, replaced, rotated and aligned.
    After leaving shop, inflated new tires (44psi) and rear tires (51psi) to their maximums.
    Firestone is now ordering shifter lever bearing for my Civic. Should call sometime today.
  4. PaleMelanesian
    I found the best pressure balance to be higher front lower rear, at least with the same tires all around. 3-5 lower in the back. Otherwise, the back end skips sideways a bit on rough surfaces and bumps. Your 51-psi tires might be softer and negate the difference, though.
    Are those rears GY Fuelmax? If so, they're definitely softer and can handle the higher pressure better.
  5. LinuxGold
    So are you suggesting 44psi front and 43psi rear?
  6. PaleMelanesian
    See, I'm not sure where to go with this. I'm running 70/65 on my 44's, but won't/can't recommend that to you. (cya ;)) How's the treadwear on the rears? Would it be worth swapping them to the front? Or just go with what you have. As long as your traction and suspension handle it in your conditions, you'll be fine. Just know the limits and be prepared to drive around them. I know exactly where my traction limits are in various conditions - wet or dry, smooth or rough. It's that last one where high pressure is an issue.
  7. LinuxGold
    Gotcha.
  8. LinuxGold
    I converted 3gp to mp4, uploaded into my gallery, I couldn't seem to play the video on (in Chrome):
    P&G, one time NICE-ON and one time DWL
    I'm not good with multimedia files, can anyone help?
  9. LinuxGold
    For the record on my own thread...
    76.8 MPG / 2.2 miles -- highest segment to date.
    63 MPG / 23.3 miles -- highest commute to date.
    59.204/565.1 miles -- highest Tank to date.
  10. LinuxGold
    My HypermilerX muffler and oil was replaced last Saturday morning. When I left Firestone, the car engine was suffocating badly, I mean, badly! I quickly returned back to Firestone and pointed this out to the Manager. He took it back in, re-checked, replaced oil and everything. He found out that the spark plug and wire was burnt out, replaced it for free! (180 dollars worth.) My HX is running smoothly and a lot better than what it was before.
    Before the spark plug was replaced, it was staggering like if there were air in gas tube every time when I tried to start out of FAS. Now that the spark plug and cable was replaced, it now no longer staggering when I went out of FAS. When going up the hill or bridge, I am able to go lower on LOD and going stronger.
    It is amazing to see how a hypermilerx can see a BIG difference with a simple tune up!
  11. LinuxGold
    69.9 MPG / 20.5 miles -- highest commute to date.
  12. LinuxGold
    81.4 MPG / 2.1 miles -- highest segment to date.
    76.6 MPG / 22.4 miles -- highest commute to date.
    59.204 MPG / 565.1 miles -- highest Tank to date.
  13. msirach
    Looks like you are still improving. Warm temps coming and it should get easier!
  14. LinuxGold
    Yep! That was what I did with Abilene, Toyota Camry, that went to junk yard not long ago.
  15. FSUspectra
    Excellent! :)
  16. LinuxGold
    99.2 MPG / 1.1 miles -- highest segment to date.
    76.6 MPG / 22.4 miles -- highest commute to home to date
    78.2 MPG / 23.8 miles -- highest commute to work to date
    63.84 MPG / 647.6 miles -- highest Tank to date.
  17. LinuxGold
    On my gas refill, departing from gas station to the traffic light:
    344 mpg over .1 mile
  18. LinuxGold
    Ok.
    Logging in my thread to keep track of my troubles...
    Actual and logged into mileage log:
    461 miles, 8.472 gallons, 54.41 MPG
    ScanGaugeII:
    465 miles, 6.83 gallons, 68 MPG
    Possible scenario (sorted by most possible) and solution
    Column1Column2
    Scenariosolution
    5th gear @ 20mph from stopchange to 35mph
    5th gear @ 30mph from uphillchange to 35mph
    Siphoning gas tankBuy new gas cap with key
    Possible engine problemFirestone to check car out
    Muffler misaligned (evidently)Have Firestone fix their mistake
    Delta of 25 @ 50 mph MAXReduce Delta to 15 @ 50 mph MAX
  19. FSUspectra
    What do you mean by the muffler being misaligned?
  20. LinuxGold
    Brandon,
    I had muffler replaced not long ago by Firestone with chrome fitting on it. Two days ago I noticed that chrome fitting is loose and that the pipe is pointed half way between behind the skirt and space where it should be.
