2011 Hyundai Sonata Specifications
Discussion in 'New Automobile Specifications' started by xcel, Jun 14, 2010.
    Pricing:
    2011 Hyundai Sonata Manufacturer’s Suggested Retail Pricing
    Column1Column2Column3Column4
    ModelEngineTransmissionMSRP
    GLS2.4-liter GDI I4Six-Speed M/T$19,195
    GLS2.4-liter GDI I4Six-Speed A/T$20,195
    GLS with Pop. Equip. Pkg.2.4-liter GDI I4Six-Speed A/T$20,945
    GLS with Pop. Equip. Pkg. + Navi.2.4-liter GDI I4Six-Speed A/T$22,645
    SE2.4-liter GDI I4Six-Speed A/T$22,595
    SE with Navi. & Sunroof Package2.4-liter GDI I4Six-Speed A/T$25,195
    Limited2.4-liter GDI I4Six-Speed A/T$25,295
    Limited with Navi. Pkg.2.4-liter GDI I4Six-Speed A/T$27,395
    Current Delivery and Handling: $720
    Engineering:
    Engine Type: Gasoline Direct Injected (GDI) In-Line 4-Cylinder
    Displacement (cc): 2,359
    Horsepower @ rpm:
    GLS/Limited ULEV-II - 198 HP@6,300 RPM
    GLS/Limited PZEV - 190 HP@6,300 RPM
    SE ULEV-II - 200 HP@6,300 RPM
    Torque (lb.-ft. @ rpm)
    GLS/Limited ULEV-II – 184 lb-ft. @4,250 RPM
    GLS/Limited PZEV - TBA
    SE ULEV-II - 186 lb-ft. @4,250 RPM
    Bore and Stroke (in): 3.46” x 3.82”
    Compression Ratio: 11.3:1
    Valvetrain: DOHC CVVT (Continuously Variable Valve Timing)
    Direct injection
    Front-Wheel Drive
    CARB Emissions Rating: ULEV-II
    Transmissions:
    Gear Ratios
    6-Speed Manual Transmission
    1st: 3.27
    2nd: 1.93
    3rd: 1.70
    4th: 1.28
    5th: 1.03
    6th: 0.83
    Final Drive: (1,2,R)- 4.33/(3-6)- 3.25
    Reverse: 3.59
    RPM at 60 mph: 1,904 RPM
    6-Speed Automatic Transmission (available)
    1st: 4.21
    2nd: 2.64
    3rd: 1.80
    4th: 1.39
    5th: 1.00
    6th: 0.77
    Final Drive: 2.89
    Reverse: 3.39
    RPM at 60 mph:
    GLS 6-speed MT - 1,904 RPM
    GLS 6-speed AT - 1,825 RPM
    Limited 6-speed AT - 1,868 RPM
    SE 6-speed AT - 1,854 RPM
    Body/Suspension/Chassis:
    Unit-Body Construction
    Multi-link Rear Suspension
    Stabilizer Bar (mm., front/rear): 24 mm/15 (GLS/Limited) and 17 (SE) mm
    Electric Power Steering (EPS) steering column mounted, Rack-and-Pinion
    Steering Wheel Turns, Lock-to-Lock: 2.34
    Steering Ratio: 14.5:1
    Turning Diameter, Curb-to-Curb (ft.): 35.8
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.8/11.2
    Wheels:
    16 x 6.5-in. steel wheel with full covers (GLS)
    16 x 6.5-in. alloy wheel (GLS Optional)
    18 x 7.5-in. hyper silver alloy (SE)
    17 x 6.5-in. alloy (Limited)
    All-Season Tires:
    P205/65R16 (GLS)
    P225/45R18 (SE)
    P215/55R17 (Limited)
    T125/80D16 (Compact temporary use spare tire)
    Interior Measurements:
    Headroom (in., front/rear): 40.0/37.8
    Legroom (in., front/rear): 45.5/34.6
    Shoulder Room (in., front/rear): 57.9/56.7
    Hiproom (in., front/rear): 55.2/54.9
    Cargo Volume (cu. ft.): 16.4
    Passenger Volume (cu. ft.): 103.8
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 110.0
    Length (in.): 189.8
    Height (in.): 57.9
    Width (in.): 72.2
    Track (in., front/rear):
    16-in. wheels - 62.9 in. / 62.9 in.
    17-in. wheels - 62.6 in. / 62.6 in.
    18-in. wheels - 62.5 in. / 62.5 in.
    Curb Weight (lbs. MT/AT): 3,161/3,199 to 3,316
    Weight Distribution (%, front/rear, MT): 60/40
    Weight Distribution (%, front/rear, AT): 60/40
    Cd: 0.28
    6-Speed Manual (City/Highway/Combined mpgUS): 24/35/28
    6-Speed Automatic (City/Highway/Combined mpgUS): 22/35/26
    Crankcase (qt.): 4.9
    MT/AT transmission fluid (qt.): 1.9/7.5
    Coolant System (qt.): 7.0
    Fuel (gal.): 18.5
  2. PaleMelanesian
    1900 rpm at 60! That's the spec I scrolled down to find, and Boy Howdy does it look good!
    A friend of a friend just got one and claims 43 mpg on the interstate.
