Possible Gen 3 Prius codes for ScanGauge
Discussion in 'ScanGauge' started by TheForce, Dec 27, 2009.
  1. TheForce
    TheForce He who posts articles
    I take no credit for this but I'm posting here because I know some Prius owners here don't visit to priuschat.com and some here with SG programming knowledge may not visit priuschat.com.
    Anyway frenchie from priuschat posted a link to some possible ScangGuage codes for the Gen 3 Prius.
    Gauges that might be available are...
    SOC
    AMP
    HV
    RPM
    I'm not that knowledgeable in SG programming and I dont have a Gen 3 Prius to try it out. So if anyone here knows how to program the SG and has a Gen 3 Prius to try it on please let us know if these codes will work.
    Here is the link to the priuschat.com post.
    http://priuschat.com/forums/gen-iii-2010-prius-technical-discussion/73944-obdii-codes.html
    Here is a link to the codes.
    http://prius-touring-club.com/documents/prius_gen3_can_codes_v001.pdf
  2. CarlD
    CarlD Well-Known Member
    Well, just like before much of the stuff is buried in multi-frame responses. Only way to get that stuff is with a rev of the SG firmware that sends the flow control frame. The 3.18f version I have does this, but alas, I have no Prius to test.
    Amps come from a single-frame response so no problem there.
    Amps
    TXD: 07E2218A
    RXF: 0461458A0000
    RXD: 2810
    MTH:000100018000
    NAM: Amp
  3. undrgnd
    undrgnd New Member
    And how does one get the 3.18f firmware? I take it it's not something one can download and flash at home?
  4. adrianblack
    adrianblack Member
    What about injector volume?
    7E0802213C0000000000
    7E8807613C209307F580
    Injection Volume mL
    &h2093 = 8339
    8339 / 32365 = 0,258 mL
    I will go try to AMP's and see if it works.
  5. adrianblack
    adrianblack Member
    This works in that it returns a value that is certainly changing as it would with amps, but the math isn't right. With ICE off I was getting 1.17amps. With the headlights on, 2.xx ... but with the ICE running and charging the battery it was 635-655 amps.
    ICE running is charging the battery but with it off amps should be negative.
  6. CarlD
    Yup, I forgot that the SG has a bug when using the 100X with negative values. the 655 is actually a negative 1. (-1 in 2's complement is 0xFFFF = 65,535 decimal and when the decimal point is moved 2 places it becomes 655.)
    So the RXF must be changed to:
    RXF: 0461858A0000 (was a 4)
    and the MTH changed to:
    0001000AF334
    should give correct negative current readings.
    -cd-
  7. adrianblack
    adrianblack Member
    Thank you for explaining this bug to me. I knew something was up with those 650's as they were so close to 65535 or -1 ...
    This XGAUGE works perfectly now.
    Ok, here are the two Xgauges that I know of that work now (just tested them on a test drive)
    Battery AMPs for Gen III prius (- values are charging, + values are draw)
    TXD: 07E2218A
    RXF: 0461858A0000
    RXD: 2810
    MTH: 0001000AF334
    Fuel Injector Volume (ml) for Gen III Prius
    TXD: 07E0213C
    RXF: 0461453C0000
    RXD: 2810
    MATH: 000101440000
    (Sadly when the ICE shuts off, the computer keeps reporting the last known value ... it does not show 0.00 except when you first turn on the car before the ICE starts.)
  8. adrianblack
    adrianblack Member
    Here are the codes to control the Reverse Beep on the 2010 Prius
    Query Reverse Beeper (shows 0000 is enabled, 0040 is disabled)
    TXD: 07c021ac
    RXF: 046115ac0000
    RXD: 2808
    MTH: 000100010000
    Set Reverse Beeper Off
    TXD: 07c03bac40 (change last 40 to 00 if you want to re-enable it)
    RXF: 047b15ac0000
    RXD: 2008
    MTH: 000100010000
    And a video showing me manipulate it
    http://www.youtube.com/watch?v=qzWltfX2y6Q
    Edit: New video because youtube is not processing MOV files properly. (Converted to MP4 and reuploaded.)
  9. TheForce
    WOW! Controlling the reverse beeper via the SG is AWESOME! :D GREAT FIND! Will it stay that way forever with the scangauge removed and the car power cycled?
  10. bestmapman
    If I could make a request, it would be to find the SOC value the the scan guage.
  11. ksstathead
    ksstathead Moderator
    Yes, the xguage only needs to be run when the 12V is disconnected, as I understand it. My reverse beeper beeps once each time I shift to reverse and the SG is not even in the Prius.
    Attaboy AdrianBlack et al.
