2007 Nissan Altima Hybrid
Discussion in 'New Automobile Specifications' started by xcel, Nov 15, 2006.
    Engineering:
    Displacement (cc): 2,488
    Horsepower @ rpm (SAE net, Rev 1/05): 158 @ 5,200 - 6,000 RPM
    Horsepower Net Combined (SAE net, Rev 1/05): 198
    Torque (lb.-ft. @ rpm): 162 @ 2,800 - 4,800 RPM
    Bore and Stroke (mm): 9.0 x 100.0
    Compression Ratio: 9.6:1
    Valvetrain: DOHC 16V, w/ CVTCS
    Sequential multi-point electronic fuel injection
    Drive-by-Wire Throttle System
    Front-Wheel Drive
    CARB Emissions Rating: AT-PZEV
    Cd: .31
    Electric Motor/Generator(s):
    Power output: 40 HP @ 0 - 1,500 RPM
    Torque: 199 lb.-ft. @ 0 - 1500 RPM
    Battery Power Storage:
    Ni-MH
    Voltage: 244.8 V
    System Voltage: 650 V maximum
    Transmission:
    E-CVT
    Body/Suspension/Chassis:
    Unit-Body Construction
    Independent Multi-Link Rear Suspension
    Stabilizer Bar (mm., front/rear): 24.2 mm/17.3 mm
    Electric Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 2.76
    Steering Ratio: 2.83:1
    Turning Diameter, Curb-to-Curb (ft.): 37.4 ft.
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.7/11.5
    Wheels: All-Season Tires: P215/60 R16 Continental, ContiPro Contact
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 40.6/36.8
    Legroom (in., front/rear): 42.2/34.5
    Shoulder Room (in., front/rear): 55.7/55.5
    Hiproom (in., front/rear): 56.8/52.5
    Cargo Volume (cu. ft.): 9.1
    Passenger Volume (cu. ft.): 100.7
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 109.3
    Length (in.): 189.8
    Height (in.): 58.1
    Width (in.): 69.6
    Track (in., front/rear): 60.7/60.4
    Curb Weight (lbs.): 3,448
    CVT (City/Highway): 41/36
    Crankcase (qt.): 4.5
    Coolant System (gal.): 2.0
    Fuel (gal.): 20.0
  2. Mr. Kite
    Mr. Kite Well-Known Member
    It's too bad that the car will not be more widely available.
    http://www.nissannews.com/nissan/news/products/20060420121506.shtml
    Hi Mr. Kite:
    ___Besides Nissan releasing the Altima Hybrid into the new 8 clean states, Ghosn has repeatedly stated Hybrids are bad for his business in a number of places … This one came from Reuters a few months ago.
    ___And to find out Nissan will be selling the Altima hybrid throughout Canada?
    Nissan’s Fuel Efficient, Low-emission Altima Hybrid to Reach Canada Early 2007.
