2003 - 2005 Honda Civic Hybrid CVT/MT
Discussion in 'New Automobile Specifications' started by xcel, Mar 15, 2006.
    Engineering:
    Displacement (cc): 1339
    Horsepower @ rpm (SAE net / with IMA): 85 @ 5700/93 @ 5700//85 @ 5700/93 @ 5700
    Torque (lb.-ft.@ rpm /with IMA): 87@ 3300/105@3000//87@3300/116 @ 1500
    Bore and Stroke (mm): 73x80
    Compression Ratio: 10.8:1
    Valvetrain: 8-Valve SOHC VTEC
    Multi-Point Fuel Injection
    Ignition System : "intelligent" Dual & Sequential Ignition (i-DSI)
    Front-Wheel Drive
    CARB Emissions Rating: ULEV/AT-PZEV
    Federal Emissions Rating: Tier II/Bin2/Tier II/Bin5
    105,000 Miles Tune-Up Interval
    Cd: 0.28
    IMA Electric Motor/Generator
    Horsepower @ RPM: 13.4 hp @ 4000 RPM
    Torque (lb.-ft.@ rpm): 46 @ 1000 RPM
    IMA Power Storage
    Ni-MH
    Voltage: 144V (120 Cells @ 1.2V)
    Rated Cap: 6.0 Ah
    Transmissions:
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.462 2nd: 1.870 3rd: 1.241 4th: 0.912 5th: 0.711 Final Drive: 3.600
    Reverse: 3.231
    Continuously Variable Transmission
    2.367 - 0.407 - Final Drive: 5.778
    Reverse: 4.226 - 3.214
    Body/Suspension/Chassis:
    Unit-Body Construction
    Reactive-Link Double Wishbone Rear Suspension
    Stabilizer Bar (mm., front/rear): 25.4 mm/13.0 mm
    Electric Power-Assisted Rack-and-Pinion Steering (EPS)
    Steering Wheel Turns, Lock-to-Lock: 2.71
    Steering Ratio (ULEV/SULEV): 14.64/14.82
    Turning Diameter, Curb-to-Curb (ft.): 34.8 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.3/8.7
    Wheels: 14" Lightweight Alloy
    All-Season Tires: P185/70 R14 87S
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 39.8/37.2
    Legroom (in., front/rear): 42.2/36.0
    Shoulder Room (in., front/rear): 52.6/52.0
    Hiproom (in., front/rear): 51.2/49.8
    Cargo Volume (cu. ft.): 10.1
    Passenger Volume (cu. ft.): 91.4
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 103.1
    Length (in.): 175.4
    Height (in.): 56.3
    Width (in.): 67.5
    Track (in., front/rear): 57.9/57.9
    Curb Weight (lbs. ULEV/SULEV): 2732/2740//2661/2669
    Weight Distribution (%, front/rear): 59/41
    5-Speed Manual (City / Highway) (ULEV): 46/51
    CVT (City/Highway) (ULEV): 48/47
    5-Speed Manual (City / Highway) (SULEV): 45/51
    CVT (City/Highway) (SULEV): 47/48
    Crankcase (qt.):
    Coolant System (gal.):
    Fuel ULEV/SULEV (gal.): 13.2/11.9
