2006 Toyota Corolla LE
Discussion in 'New Automobile Specifications' started by xcel, Mar 14, 2006.
    Engineering:
    Displacement (cc): 1794
    Horsepower @ rpm (SAE net, Rev 8/04): 126 @ 6000 RPM
    Torque (lb.-ft. @ rpm): 122 lb.-Ft. @ 4200 RPM
    Redline (rpm):
    Bore and Stroke (mm): 79 x 91.4
    Compression Ratio: 10.0:1
    Valvetrain: DOHC 16V VVT-i
    Sequential Electronic Fuel Injection
    Front-Wheel Drive
    CARB Emissions Rating: ULEV
    Cd = 0.30
    Transmissions:
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.166 2nd: 1.904 3rd: 1.310 4th: 0.885 5th: 0.725 Final Drive: 3.941
    Reverse: 3.250
    4-Speed Automatic Transmission (available)
    1st: 3.643 2nd: 2.008 3rd: 1.296 4th: 0.892 Final Drive: 2.962 Reverse: 2.977
    Body/Suspension/Chassis:
    Unit-Body Construction
    Torsion Beam Rear Suspension
    Stabilizer Bar (mm., front/rear): 23.8 mm/20 mm
    Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 3.36
    Steering Ratio: 19.5:1
    Turning Diameter, Curb-to-Curb (ft.): 36.1 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.8/7.87
    Wheels: All-Season Tires: P195/65R15
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 39.3/37.1//37.8/37.0 w/ Moonroof
    Legroom (in., front/rear): 41.3/35.4
    Shoulder Room (in., front/rear): 53.1/53.5
    Hiproom (in., front/rear): 51.9/46.2
    Cargo Volume (cu. ft.): 13.5
    Passenger Volume (cu. ft.): 90.3//88.5 w/ Moonroof
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 102.4
    Length (in.): 178.3
    Height (in.): 58.5
    Width (in.): 66.9
    Track (in., front/rear): 58.3/57.5
    Curb Weight (lbs. MT/AT): 2550/2615 - LE
    5-Speed Manual (City/Highway): 32/41
    5-Speed Automatic (City/Highway): 30/38
    Crankcase (qt.): 3.7
    Coolant System (qt.): 6.3
    Fuel (gal.): 13.2
