HCHII Wreck
Discussion in 'Honda Hybrids' started by psyshack, Oct 20, 2009.
  1. psyshack
    Here are all the pics I have of the car. http://www.cleanmpg.com/photos/showgallery.php/cat/639
    You can't see the over all damage until you start peeling back the sheet metal. The ACE structure did it's job. It absorbed and transferred the impact and gave it's all. I have no idea why the air bags did not deploy. Her sternum is sore but not so much as a cut or bruise. I think some traction and broken bones would have done her more good than state of the art engineering and a worthless car after the fact. Maybe if she was reminded a bit here and there with a pain or so here and there she would pull her head out. Not to mention the time laying in a bed to think about it.
    Her next car if I ever buy her one will be a striped Yaris or Fiat 500. Used of course. :)
  2. hunter44102
    hunter44102 Well-Known Member
    PSY - get her a bright yellow car. Apparently they are the most visible and a smaller percentage less likely to be in accident.
    Also, according to this article, 30% of us have a gene that makes us bad drivers and don't learn from mistakes:
    http://www.dailytech.com/article.aspx?newsid=16670
  3. ioverholt
    ioverholt Member
    psyshack,
    Seems like it could be pulled straight. Maybe straight-ish. At least straight enough. :D Can't the whole front clip be replaced? I mean the structural members forward of the firewall and A-pillars.
    It's an expensive repair for sure. If possible, I'd repair it and sell it. Did you get any estimates on replacing the front clip and pulling the rest of the chassis straight? That cost would tell you if it's worth fixing and selling, or just parting out.
    Good luck and I hope your wife pays more attention in the future.
  4. psyshack
    OOO but a new twist takes place. Chatty Okies yeah know. People know my wifes x husband and brothers at the shop the HCHII is at. All known to be craftsman in the trade of Wreck fixers. Coupled with the fact I'm a doc'ed finisher and spray tech from thimbles to aircraft.
    They all know each other..... The wifes blood runs deep in the collision repair game.
  5. msirach
    That statement explains her driving record. It's just natural for her to "drum up business" for the family! ;)
  6. xcel
    Hi Jeff:
    ___I suspect your HCH-II will be better than ever and this will be a long and distant memory in another 3 to 6-months. At least I hope so for both your sakes :love:
  7. greenrider
    greenrider Well-Known Member
    Honestly, I'd be in marital counseling at the least, or headed for divorce court. Is gross negligence grounds for divorce?
  8. Kacey Green
    Kacey Green Well-Known Member
    we have a few of those lifts at the shop
  9. JusBringIt
    JusBringIt Be Inspired
    My fiance hasn't been in any accidents in the 3 1/2 years since I taught her to drive and had her get her license...;). It pays to be the teacher.
  10. psyshack
    Went in to check up on the car today. The engine and tranny are out of it. They have started the heavy body work. The new front right stake/brace that took the hit has been installed. Which involved replacing most of the under pinning on the front right. Once that was in I was told they put it on the rack and pulled it back straight again. When I was there they were preping for the last welds. Once completely welded up it will go back on the rack for another check. Then all the welds will be sealed up and the painting under the hood will be complete. They said it pulled very well and showed me the report, of which we should get a copy of when we pick up the car. Still going to take 2 to 3 more weeks before it's ready. All parts are OEM. The fenders were dry fitted today and basic prime and sealing paint work has started on them.
  11. phoebeisis
    Wow, steel is wonderful stuff. They replace the parts that are bent beyond repair , straighten the slightly bent ones. Pretty sure that will never happen with aluminum.
    Amazing.
    Luck
    Charlie
  12. St. Mushroom
    St. Mushroom doesn't wash his car.
    Are you worried about the mechanic's ability to repair the ACE body structure?
  13. psyshack
    Me worried? Naw, I wrote it off as soon as I saw the car.
  14. St. Mushroom
    I remember when I got rear-ended in my 07 sedan a while back, I was thinking, does the adjuster actually know how to assess damage for this thing, which as far as I'm concerned, as a mechanically-challenged consumer, is a magical load-dispersing frame. Guess I drank the HMC cool aid!
  15. PaleMelanesian
    My understanding is that the ACE structure starts at the firewall. What's in front of that is designed to crush and bend and sacrifice itself. That's exactly what it did here. Better to replace the whole front clip than to lose a person.
  16. psyshack
    Fenders have been primed and sealed. They were fitting them when I stopped in. Door trim was being pulled off so they could blend in the fenders.
  17. Mendel Leisk
    The front fenders are actually pretty flimsy pieces, over the more substantial wheel well sub-frame: sort of like a motorcyle fairing, just a few bolts and clips hold it on. That makes for easier front end repair, anyways.
    We just had ours replaced, plus both doors, down one side, due to a T-bone accident.
  18. psyshack
    Went by the body shop today. Paints on it. Fenders look like crap. They are not aligning up at the A pillar or the lower rocker panel. So If they put paint on it as if that was good enough. I'm sure the engine and transmission were yanked out and put back in correct,,,, NOT! I have concerns about the A/C system and the electric power steering unit. Big sign on it stating " check transmission fluid ". They had the cooling lines off. So I hope they put the right fluid back in.
    I'm waiting to see how she handles the curbed wheel and screwed up back bumper along with it needing the oil changed and tires rotated. I will never drive it again much less service it. I gave her a hint today. " When you inspect it, pay and pick it up,,, you might, maybe, should get it to a local Honda dealer and have it's maint. done. Have the firmware upgraded, and have the TSB done on the spoiler,,, OOOO and have the drivers door window regulator checked. And maybe have the transmission fluid checked if not changed out. A full flush if the body shop can not produce a bottle of Honda CVT tranny fluid. And then figure out a way to have the body shop pay for the flush if they did screw it up.
    See how it goes. She should have it the middle of the week.
  19. 98CRV
    98CRV Well-Known Member
    Does wifey have ADHD? ADHDers are good for wrecking cars, losing stuff, getting divorced....
  20. raveneon
    raveneon Well-Known Member
    Why is this work not being performed by a Honda dealer?
