2006 - 2009 Toyota Prius-II
Discussion in 'New Automobile Specifications' started by xcel, Mar 13, 2006.
    2006 Toyota Prius
    Engineering:
    Displacement (cc): 1497
    Horsepower @ rpm (SAE net, Rev 8/04): 76 HP @ 5000 RPM
    Torque (lb.-ft. @ rpm): 82 lb.-ft. @ 4200 RPM
    Redline (rpm):
    Bore and Stroke (mm): 75 x 84.7
    Compression Ratio: 9.5:1
    Expansion Ratio: 13.0:1
    Valvetrain: DOHC 16-valve VVT-i
    Multi-Point Fuel Injection
    Drive-by-Wire Throttle System
    Front-Wheel Drive
    CARB Emissions Rating: AT-PZEV
    Federal Emissions: Tier II/Bin3
    HSD Electric Motor/Generator:
    Power output: 67 hp @ 1200-1540 rpm (50 kW @ 1200-1540 rpm)
    Torque: 295 lb.-ft. @ 0-1200 rpm (400 Nm @ 0-1200 rpm)
    HSD Power Storage:
    Ni-MH
    Voltage: 201.6V
    28 hp (21 kW)
    Transmission:
    ECVT
    Body/Suspension/Chassis:
    Unit-Body Construction
    Torsion Beam Rear Suspension
    Stabilizer Bar (mm., front/rear): 20 mm/21 mm
    Electric Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 3.7
    Steering Ratio: 19.1:1
    Turning Diameter, Curb-to-Curb (ft.): 34.1 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.0/7.9
    Wheels: All-Season Tires: P185/65R15
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 39.1/37.1
    Legroom (in., front/rear): 41.9/38.6
    Shoulder Room (in., front/rear): 55.3/53.0
    Hiproom (in., front/rear): 51.0/51.6
    Cargo Volume (cu. ft.): 16.1
    Passenger Volume (cu. ft.): 96.2
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 106.3
    Length (in.): 175.0
    Height (in.): 58.1
    Width (in.): 67.9
    Track (in., front/rear): 59.3/58.3
    Curb Weight (lbs. MT/AT): 2890
    Weight Distribution (%, front/rear): 59/41
    Cd: 0.26
    EPA (City/Highway): 60/55 mpg
    Crankcase (qt.):
    Coolant System (qt.): 8.2
    Fuel (gal.): 11.9
