2007 Toyota Yaris 3-Dr. Hatchback/Sedan
Discussion in 'New Automobile Specifications' started by xcel, Mar 13, 2006.
    2007 Toyota Yaris 3 Dr. Hatchback/Sedan
    Pricing:
    Yaris 3-Door Liftback 5-Speed Manual $11,050
    Yaris 3-Door Liftback 4-Speed Automatic $11,950
    Yaris 4-Door S Sedan 5-Speed Manual $13,425
    Yaris 4-Door Sedan 5-Speed Manual $11,925
    Yaris 4-Door Sedan 4-Speed Automatic $12,650
    Yaris 4-Door S Sedan 4-Speed Automatic $14,150
    Destination $620
    Base - Option packages - higher trims have far fewer options to add due to inclusion.
    Option Combination #A $740
    All-Weather Guard Package - Larger Washer Tank w/ Level Warning, Heavy-Duty Heater, Heavy-Duty Starter, Rear Heater Duct & Daytime Running Lights (DRL) (CP)
    Convenience Package - AM/FM CD Player w/MP3/WMA Playback Capability & Auxiliary Audio Jack, 15-in. Steel Wheels w/Full Wheel Covers, Rear Window Wiper & Rear Defroster (CQ)
    Option Combination #B $1,400
    Power Package - Power Door Locks, Power Windows, Power Outside Mirrors, 60/40 Split, Reclining, Sliding, Fold-flat Rear Seat, AM/FM CD player with MP3/WMA Playback Capability and Auxiliary Audio Jack, Rear Window Wiper, Rear Defroster and 15-in. Steel Wheels (PQ)
    Option Combination #C $2,350
    4-wheel Anti-Lock Brake System (ABS) w/Electronic Brake-Force Distribution (EBD) (AB)
    Driver & Front Passenger Front Seat-Mounted Side Airbags & Front & Rear Side Curtain Airbags (GY)
    Option Combination #D $2,890
    Fog Lamps (LF)
    Rear Spoiler (RF)
    Remote Keyless Entry System (KE)
    Option Combination #E $3,280
    Fog Lamps (LF)
    Power Package - Power Door Locks, Power Windows, Power Outside Mirrors, 60/40 Split, Reclining, Sliding, Fold-Flat Rear Seat, AM/FM CD Player w/MP3/WMA Playback Capability & Auxiliary Audio Jack, Rear Window Wiper, Rear Defroster & 15-in. Aluminum Alloy Wheels (PP)
    Rear Spoiler (RF)
    Cargo Logic Tote (9G) $40
    Cargo Net (GN) $49
    Door Sill Enhancements (G0) $159
    Emergency Assistance Kit (7R) $70
    First Aid Kit (3Z) $29
    Interior Light Kit - Blue (44) $275
    Rear Bumper Protector (EF) $65
    Sport Shifter Knob (22) $65
    VIP Security (V3) $499
    Wheel Locks (WL) $59
    TRD 18" Wheel (Single Wheel/Tire not included) $330
    TRD Oil Filler Cap $57
    TRD Radiator Cap $38
    TRD Shift Knob $76
    Engineering:
    Displacement (cc): 1496
    Horsepower @ rpm (SAE net, Rev 8/04): 106 HP @ 6000 RPM
    Torque (lb.-ft. @ rpm): 103 lb.-ft. @ 4200 RPM
    Redline (rpm):
    Bore and Stroke (mm): 74.9 x 84.6
    Compression Ratio: 10.5:1
    Valvetrain: 16-Valve DOHC VVTi
    Sequential Electronic Fuel Injection
    Front-Wheel Drive
    CARB Emissions Rating: ULEV-2
    100,000-Miles-or-More Tune-Up Interval*
    Transmissions:
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.545 2nd: 1.904 3rd: 1.310 4th: 0.969 5th: 0.815 Final Drive: 3.722
    Reverse: 3.250
    5-Speed Automatic Transmission (available)
    1st: 2.847 2nd: 1.552 3rd: 1.000 4th: 0.700 Final Drive: 4.237 Reverse: 2.343
    Body/Suspension/Chassis:
    Unit-Body Construction
    Torsion Beam Rear Suspension
    Stabilizer Bar (mm., front/rear): 23 mm/NA
    Electrical Power Assist Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 3.02
    Steering Ratio: 19.7:1
    Turning Diameter, Curb-to-Curb (ft.): 32.6 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.03/7.87
    Wheels: 14" with Full Covers//15" Steel or Alloy
    All-Season Tires: P175/65 R14//P185/60 R15
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 39.4/37.5//38.8/36.7
    Legroom (in., front/rear): 40.3/33.8//42.2/35.6
    Shoulder Room (in., front/rear): 51.4/48.3//51.6/50.2
    Hiproom (in., front/rear): 50.0/48.3//49.8/50.1
    Cargo Volume (cu. ft.): 12.8/12.9
    Passenger Volume (cu. ft.): 84.1/87.1
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 96.9//100.4
    Length (in.): 150.0//169.3
    Height (in.): 60//56.7
    Width (in.): 66.7//66.5
    Track (in., front/rear): 57.59/57.5//58.3/57.9
    Curb Weight (lbs. MT/AT): 2293/2326
    Cd: .29
    5-Speed Manual (City/Highway): 34/40
    5-Speed Automatic (City/Highway): 34/39
    Crankcase (qt.): 4.3
    Coolant System (qt. MT/AT): 5.4
    Fuel (gal.): 11.1
  2. philmcneal
    intresting... the yaris sedan for canada has a 4 speed auto with overdrive hm...
    Hi Phil:
    ___I sort of wish Toyota would have offered the D4D in the Canadian based Yaris as that thing would have been a FE monster! Having access to the 5-Dr. hatch is also a plus for our North of the border membership vs. the std. 3 Dr. Hatch and 4-Dr. Sedans available here in the US …
  4. philmcneal
    http://www.cartalkcanada.com/blog/?p=85 it seems the yaris has better gearing than the fit on the highway! 3000 rpms = 120 km/h! as opposed to the fit's 100 km/h although his tester was a 4 spd auto and the fit 5 spd auto had a taller 5th than the fit's manual.... go figures.
  5. psyshack
    I saw the car in Snotsdale dealer when I was in PHX two weeks ago. It is truley a ugly small cheap looking car. And that center pod really blows. Couple that with Yotas holy rooler we are better than god tude. Its not worth a test drive.
  6. xcel
    Hi Psy:
    ___Not all Toyota dealerships are as bad as you have experienced. I picked up the 03 Corolla LE just a few months after release for $250 over invoice back in 02 if that helps. For the price, a very minimally equipped (stripped down) Yaris for ~ $11K is not a bad deal for a fuel efficient automobile for those that simply cannot afford anything more imho.
    ___As for the center mounted pod/gauge cluster, Toyota was trying to save bucks for a single layout across Europe, Japan, and the US from my understanding. It is still somewhat Echo’ish in interior appearance but it works.
  7. philmcneal
    hey a good 06 corolla 5 spd might not be a bad choice, good power to weight ratio.
  8. AshenGrey
    AshenGrey Well-Known Member
    I wonder why the American Yaris doesn't have the IISS option the way it does in Japan? IISS is a light hybrid system that adds an additional 5 MPG to the car's fuel economy.
  9. philmcneal
    i'm considering the toyota echos since they are 300 pounds lighter than its yaris counterpart... but i think the areodynamic drag is .3 compared to the yaris .29. Plus the gearing on the echo is better, only 2600 for 5th gear @ 60 mph.
    plus prices are a bargin! only starting at 10000 with low mileage!
