2006 Honda Accord I4 LX/EX
Discussion in 'New Automobile Specifications' started by xcel, Mar 11, 2006.
    Engineering:
    Displacement (cc): 2354
    Horsepower @ rpm (SAE net, Rev 8/04): 166 @ 5800
    Torque (lb.-ft. @ rpm): 160 @ 4000
    Redline (rpm): 6500
    Bore and Stroke (mm): 87x99
    Compression Ratio: 9.7:1
    Valvetrain: 16-Valve DOHC i-VTEC (R)
    Multi-Point Fuel Injection
    Drive-by-Wire Throttle System (TM)
    Front-Wheel Drive
    CARB Emissions Rating: LEV-2//PZEV
    EPA Emissions Rating: Tier II/Bin5//Tier II/Bin2
    100,000-Miles-or-More Tune-Up Interval
    Transmissions:
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.267 2nd: 1.769 3rd: 1.147 4th: 0.872 5th: .659 Final Drive: 4.389
    Reverse: 3.583
    5-Speed Automatic Transmission (available)
    1st: 2.652 2nd: 1.517 3rd: 1.037 4th: 0.738 5th: 0.566 Final Drive: 4.438
    Reverse: 2.000
    Body/Suspension/Chassis:
    Unit-Body Construction
    Double Wishbone Front Suspension
    Five-Link Double Wishbone Rear Suspension
    Stabilizer Bar (mm., front/rear): 25.4/14.0
    Variable Assist Power Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 2.94
    Steering Ratio: 15.21:1
    Turning Diameter, Curb-to-Curb (ft.): 36.1
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 11.1/NA - LX
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 11.1/10.2 - EX
    Wheels: 15" with Full Covers//16" Alloy
    All-Season Tires: P205/65 R15 92H//P205/60 R16 91V
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 40.4/38.5 - LX//38.3/36.8 - EX
    Legroom (in., front/rear): 42.6/36.8
    Shoulder Room (in., front/rear): 56.9/56.1
    Hiproom (in., front/rear): 54.6/53.5
    Cargo Volume (cu. ft., seat up/down): 14.0
    Passenger Volume (cu. ft.): 102.7 - LX//97.7 - EX
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 107.9
    Length (in.): 191.1
    Height (in.): 57.2
    Width (in.): 71.6
    Track (in., front/rear): 61.1/61.2
    Curb Weight (lbs. MT/AT): 3137/3201//3168/3239
    Weight Distribution (%, front/rear, MT):
    Weight Distribution (%, front/rear, AT):
    5-Speed Manual (City/Highway): 26/34
    5-Speed Automatic (City/Highway): 24/34
    Crankcase (qt.): 5.6
    Coolant System (qt. MT/AT): 7.6/7.5
    Fuel (gal.): 17.1
  2. AshenGrey
    AshenGrey Well-Known Member
    My domestic partner's 2001 i4 Accord just keeps on chugging. It has never needed an emergency repair and has even stood up to 90% city driving with mediocre maintenance and overdue oil changes. The Accord has some good solid engineering!
