2006 - 2009 Honda Civic Hybrid
Discussion in 'New Automobile Specifications' started by xcel, Mar 11, 2006.
    2006 Honda Civic Hybrid
    Engineering:
    Displacement (cc): 1339
    Horsepower @ rpm (SAE net, Rev 8/04): 110 @ 6000
    Torque (lb.-ft. @ rpm): 123 @ 1000 - 2500
    Redline (rpm): 6300
    Bore and Stroke (mm): 73x80
    Compression Ratio: 10.8:1
    Valvetrain: 8-Valve SOHC i-VTEC
    Multi-Point Fuel Injection
    Drive-by-Wire Throttle System (TM)
    Front-Wheel Drive
    CARB Emissions Rating: AT-PZEV
    Federal Emissions Rating: Tier II/Bin2
    100,000-Miles-or-More Tune-Up Interval*
    IMA Electric Motor/Generator
    Horsepower: 20 @ 2000 RPM
    Torque: 76 lb.-ft. @ 0 - 1,160 RPM
    IMA Power Storage
    Ni-MH
    Voltage: 158 V
    Rated Cap: 5.5 Ah
    Transmissions:
    Gear Ratios
    Continuously Variable Transmission
    2.526 to 0.421 - Final Drive: 4.945
    Reverse: 4.511 to 1.875
    Body/Suspension/Chassis:
    Unit-Body Construction
    Reactive-Link Double Wishbone Rear Suspension
    Stabilizer Bar (mm., front/rear): 24.2 mm/12.0 mm
    Electric Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 2.71
    Steering Ratio: 13.52:1
    Turning Diameter, Curb-to-Curb (ft.): 34.8 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.3/8.7
    Wheels: 15" Lightweight Alloys
    All-Season Tires: P195/65 R15 89S
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 39.4/37.4
    Legroom (in., front/rear): 42.2/34.6
    Shoulder Room (in., front/rear): 53.6/52.3
    Hiproom (in., front/rear): 51.9/51.0
    Cargo Volume (cu. ft.): 10.4
    Passenger Volume (cu. ft.): 90.9
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 106.3
    Length (in.): 176.7
    Height (in.): 56.3
    Width (in.): 69.0
    Track (in., front/rear): 59.1/60.2
    Curb Weight (lbs. MT/AT): 2875
    Weight Distribution (%, front/rear): 59/41
    Cd: 0.27
    EPA Mileage Estimates*/Capacities:
    CVT (City/Highway): 49/51
    Crankcase (qt.): 3.8
    Coolant System (gal.): 5.8
    Fuel (gal.): 12.3
  2. AshenGrey
    AshenGrey Well-Known Member
    Re: 2006 Honda Civic Hybrid
    I test drove a 2006 HCH recently and it compared favorably to my 2003 HCH. I found it quieter than my 2003 and had a bit more pep to the acceleration. I couldn't tell if it ever entered EV mode during the test drive, but it was a nice smooth ride.
  3. I happen to own the 2007 model, and it's been very fantastic so far. However, for about 2 days now I've realized the auto stop function is not working. Please can someone help me out here, as to what I need to do to fix it? thanks.
