2006 Honda Civic LX/EX
Discussion in 'New Automobile Specifications' started by xcel, Mar 11, 2006.
    Engineering:
    Displacement (cc): 1799
    Horsepower @ rpm (SAE net, Rev 8/04): 140 @ 6300
    Torque (lb.-ft. @ rpm): 128 @ 4300
    Redline (rpm): 6800
    Bore and Stroke (mm): 81x87.3
    Compression Ratio: 10.5:1
    Valvetrain: 16-Valve SOHC i-VTEC (R)
    Multi-Point Fuel Injection
    Drive-by-Wire Throttle System ™
    Front-Wheel Drive
    CARB Emissions Rating: ULEV-2
    100,000-Miles-or-More Tune-Up Interval*
    Transmissions:
    Gear Ratios
    5-Speed Manual Transmission
    1st: 3.143 2nd: 1.870 3rd: 1.235 4th: 0.949 5th: 0.727 Final Drive: 4.294
    Reverse: 3.308
    5-Speed Automatic Transmission (available)
    1st: 2.666 2nd: 1.534 3rd: 1.022 4th: 0.721 5th: 0.525 Final Drive: 4.437
    Reverse: 1.957
    Body/Suspension/Chassis:
    Unit-Body Construction
    Reactive-Link Double Wishbone Rear Suspension
    Stabilizer Bar (mm., front/rear): 24.2 mm/10.0 mm
    Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 2.67
    Steering Ratio: 13.73:1
    Turning Diameter, Curb-to-Curb (ft.): 35.4 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 10.3/7.9 - LX
    Power-Assisted Ventilated Front Disc/Solid Rear Disc Brakes (in.): 10.3/10.2 - EX
    Wheels: 15" with Full Covers - LX//16” Alloys - EX
    All-Season Tires: P205/55 R16 89H//P205/55 R16 89H
    Compact Spare Tire
    Interior Measurements:
    Headroom (in., front/rear): 39.4/37.4 - LX//38.1/36.7 - EX
    Legroom (in., front/rear): 42.2/34.6
    Shoulder Room (in., front/rear): 53.7/52.4 - LX//53.6/52.3 - EX
    Hiproom (in., front/rear): 51.9/51.0
    Cargo Volume (cu. ft.): 12.0
    Passenger Volume (cu. ft.): 90.9 - LX//88.4 - EX
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 106.3
    Length (in.): 176.7
    Height (in.): 56.5
    Width (in.): 69.0
    Track (in., front/rear): 59.0/60.2
    Curb Weight (lbs. MT/AT): 2685/2751 - LX//2740/2804 - EX
    Weight Distribution (%, front/rear, MT): 60/40
    Weight Distribution (%, front/rear, AT): 61/39
    5-Speed Manual (City/Highway): 30 / 38
    5-Speed Automatic (City/Highway): 30 / 40
    Crankcase (qt.): 4.7
    Coolant System (gal. MT/AT): 6.8/7.0
    Fuel (gal.): 13.2
