2007 Nissan Sentra
Discussion in 'New Automobile Specifications' started by xcel, Oct 11, 2006.
    2007 Nissan Sentra
    Pricing:
    Sentra 2.0 2.0 Liter I4 M/T $14,750
    Sentra 2.0 2.0 Liter I4 CVT $15,550
    Sentra 2.0S 2.0 Liter I4 M/T $15,650
    Sentra 2.0S 2.0 Liter I4 CVT $16,450
    Sentra 2.0SL 2.0 Liter I4 CVT $18,400
    Sirius Satellite Radio $300
    XM Satellite Radio $300
    Splashguards (Factory Installed) $130
    Convenience Package (6 M/T) $650
    Convenience Plus Package (CVT) $900
    R-F Audio Package $750
    Sunroof Package $750
    Front Fog Lamp $270
    Anti-Lock Brake System (ABS) $250
    Alloy Wheels/ABS Package $600
    Rear Deck Lid Spoiler $210
    Body-Color Side Moldings $140
    Floor Mats and Trunk Mat (Units w/out Divider) $160
    Floor Mats and Trunk Mat (Units with Divider) $160
    Engineering:
    Displacement: 2.0L
    Horsepower @ rpm (SAE net, Rev 8/04): 140 @ 5,100 RPM
    Torque (lb.-ft. @ rpm): 147 lb-ft @ 4,800 RPM
    Redline (rpm): 6,400 rpm
    Bore and Stroke (mm): 84.0 x 90.1
    Compression Ratio: 9.7
    Valvetrain: DOHC
    Sequential Multi-Point Electronic Fuel Injection
    Front-Wheel Drive
    CARB Emissions Rating: ULEV-2
    Transmissions:
    Gear Ratios
    6-Speed Manual Transmission: 1st: 3.727 2nd: 2.105 3rd: 1.519 4th: 1.171 5th: 0.914 6th: 0.767 Final Drive: 3.933
    Reverse: 3.687
    Xtronic CVT™ Transmission: 2.349 - 0.394 Final Drive: 5.407
    Reverse: 1.75
    Body/Suspension/Chassis:
    Unit-Body Construction
    Torsion Beam Rear Suspension
    Electric Power-Assisted Rack-and-Pinion Steering
    Steering Wheel Turns, Lock-to-Lock: 2.9
    Turning Diameter, Curb-to-Curb (ft.): 35.4 ft.
    Power-Assisted Ventilated Front Disc/Rear Drum Brakes (in.): 11.02 x 0.94/9.0
    Wheels: 15'' steel with cover, 6.5JJ x 15//16'' aluminum-alloy, 6.5JJ x 16
    All-Season Tires: P205/60HR15 H-rated all-season tires//P205/55HR16 H-rated all-season tires
    Compact Spare Tire: T125/70D16
    Interior Measurements:
    Headroom (in., front/rear): 40.6/37.3
    Legroom (in., front/rear): 42.4/34.5
    Shoulder Room (in., front/rear): 56.9/55.1
    Hiproom (in., front/rear): 54.1/53.0
    Cargo Volume (cu. ft.): 13.1
    Passenger Volume (cu. ft.): 97.4/97.7 w/ sunroof
    Seating Capacity: 5
    Exterior Measurements:
    Wheelbase (in.): 105.7
    Length (in.): 179.8
    Height (in.): 59.5
    Width (in.): 70.5
    Track (in., front/rear): 59.8/60.8
    Curb Weight (lbs. MT/AT): 2,853/2,991
    Weight Distribution (%, front/rear, MT/CVT): 62/38
    6-Speed Manual (City/Highway): 28/34
    CVT (City/Highway): 29/36
    Crankcase (qt.): 3.9
    Coolant System (qt. MT/AT): 7.4
    Fuel (gal.): 14.5
