The SGII Xgauge Database
Discussion in 'ScanGauge' started by kmactavi, Jun 4, 2008.
  1. kmactavi
    kmactavi Well-Known Member
    I thought it would be helpful to have a compilation all of the useful XGAUGE documentation and codes in one spot. We can keep building this database, so feel free to list any XGAUGES that you use, but aren't listed here (with the exception of trip gauges or gauges covered in the vehicle specific PDF, see Documentation section). If you try one of these gauges, please post whether it worked/didn't work, or any modifications you made.
    Thanks to everyone who posted a gauge on various forums (TDIclub, cleanMPG), because I stole it and put it here.
    INTRO
    • Don't forget to save after entering a gauge!
    • TXDs starting with 68 6A F1 are for non-CAN (VPW, ISO, KWP) BUSes, CAN BUSes work differently (see Documentation section). All gauges listed are non-CAN unless otherwise specified.
    • CONF?: field will note if this gauge has been confirmed to work (we can also include the make/model it worked on).
    • ->NAM: field is just a suggested name.
    GAUGES
    GENERAL
    GAUGE: BOOST (TURBO)
    CONF?: YES - 2001 Jetta TDI
    UNITS: PSI
    ->TXD: 68 6A F1 01 0B
    ->RXF: 04 41 85 0B 00 00
    ->RXD: 28 08
    ->MTH: 00 91 00 64 FF 71
    ->NAM: BST
    NOTES: THIS WORKS FOR TDIs, NOT SURE ABOUT GAS TURBOS, IT USES MAP. REPLACE FF 71 (14.3 PSI) WITH 2'S COMPLIMENT OF LOCAL ATMOSPHERIC PRESSURE IN PSI (YOU CAN ADJUST THE NUMBER SO BOOST IS 0 AT IDLE). MATH IS #*145/100-143 (CONVERTS KPa -> PSI), SUBTRACTS ATM PRESS IN PSI
    GAUGE: HORSEPOWER (GAS)
    CONF?: YES-INSIGHT, ...
    UNITS: HORSEPOWER
    ->TXD: 00
    ->RXF: 40 00 80 00 00 00
    ->RXD: 00 00
    ->MTH: 00 0A 00 17 00 00
    ->NAM: HPW
    NOTES: THIS IS FOR GASOLINE VEHICLES ONLY, MATH IS #*10/23
    GAUGE: HORSEPOWER (DIESEL)
    CONF?:
    UNITS: HORSEPOWER
    ->TXD: 00
    ->RXD: 00 00
    ->MTH: 00 0A 00 24 00 00
    ->NAM: HPW
    NOTES: THIS IS FOR DIESEL VEHICLES ONLY, MATH IS #*10/36
    GAUGE: INSTANTANEOUS MPG
    CONF?:
    UNITS: MPGus (OR LPK OR MPGuk DEPENDING ON SETTINGS)
    ->TXD: 00
    ->RXF: 80 00 00 00 00 00
    ->RXD: 00 00
    ->MTH: 00 01 00 01 00 00
    ->NAM: iFE
    NOTES: OTHER TRIP GAUGES ARE SIMILAR, MODIFY TXD ACCORDING TO SG MANUAL
    GAUGE: OPEN/CLOSED LOOP (HEX)
    CONF?:
    UNITS: N/A
    ->TXD: 68 6A F1 01 03
    ->RXF: 04 41 05 03 80 00
    ->RXD: 28 08
    ->NAM: O/C
    NOTES: DISPLAYS IN HEX,
    1: Open, not yet warm
    2: Closed, normal
    4: Open, due to high load
    8: Open, system failure
    10: Closed, but something's wrong
    GAUGE: OPEN/CLOSED LOOP (ON/OFF)
    CONF?:
    UNITS: BOOLEAN
    ->RXF: 04 41 25 03 00 00
    ->RXD: 2D 01
    ->NAM: O/C
    NOTES: DISPLAYS WHETHER "OPEN, DUE TO HIGH LOAD" IS ON/OFF
    GAUGE: Manifold Air Flow
    UNITS: g/s (0 TO 655.36)
    CONF?:
    ->TXD: 68 6A F1 01 10
    ->RXF: 04 41 45 10 00 00
    ->RXD: 28 10
    ->NAM: MAF
    NOTES:
    FOR LEAN BURN HONDAS...
    GAUGE: Lean Burn
    UNITS: N/A
    CONF?: Yes
    ->TXD: 686AF10115
    ->RXF: 044105150000
    ->RXD: 2808
    ->MTH: 000100020000
    ->NAM: LBN
    NOTES: (For lean burn equipped hondas)
    If the value for LBN = 0 you are in lean burn.
    If the value is higher than zero, you are not in lean burn.
    FOR FORDS...
    GAUGE: GEAR RATIO (FORD)
    UNITS: #:1 (RATIO)
    CONF?: YES-FORD F150 2005, ...
    ->TXD: 07 E0 22 16 3B
    ->RXF: 04 62 45 16 06 3B
    ->RXD: 30 08
    ->MTH: 00 64 00 3F 00 00
    ->NAM: GRT
    NOTES: CAN BUS
    FOR THE FEH...
    (See vehicle specific link for more)
    Corrections to LL Gauge coding:
    GAUGE: Cylinder Head Temp
    UNITS: Degrees F
    ->TXD: 07 E0 22 16 24
    ->RXF: 04 62 05 16 06 24
    ->RXD: 30 10
    ->MTH: 00 02 00 01 00 00
    ->NAM: CHT
    NOTES:
    FOR THE PRIUS...
    Also See: XGauge (CAN-bus) for Dummies
    A message from Dan...
    GAUGE: STATE OF CHARGE
    CONF?: YES
    UNITS: % TOTAL CHARGE
    ->TXD: 07 E3 21 CE
    ->RXF: 05 61 86 CE 00 00
    ->RXD: 30 08
    ->MTH: 00 0A 00 02 00 00
    ->NAM: Soc
    NOTES: (PRIUS) %
    GAUGE: BATTERY VOLTAGE
    CONF?: YES, BUT FAILS OF "UPGRADED" SCANGAUGES (3.15*)
    UNITS: VOLTS
    ->TXD: 00 33
    ->RXF: 01 00 02 3B 00 00
    ->RXD: 20 10
    ->NAM: Btv
    NOTES: (PRIUS) HV BATTERY VOLTS
    GAUGE: BATTERY CURRENT
    CONF?: YES
    UNITS: +/- AMPS
    ->TXD: 07 E3 21 CE
    ->RXD: 38 10
    ->MTH: 00 01 00 0A F3 33
    ->NAM: Bta
    NOTES: (PRIUS) HV BATTERY AMPS
    GAUGE: BRAKE PEDAL POSITION
    UNITS: % OF TOTAL DEPRESSION
    ->TXD: 00 38
    ->RXF: 01 00 82 30 00 00
    ->RXD: 30 08
    ->MTH: 03 E8 00 80 00 00
    ->NAM: bps
    NOTES: (PRIUS) XX.X % DEPRESSION
    GAUGE: ENGINE TEMP (NOT COOLANT)
    UNITS: DEG C
    ->TXD: 00 31
    ->RXF: 01 00 02 39 00 00
    ->RXD: 10 08
    ->NAM: etc
    NOTES: (PRIUS) °C TEMP OF ENGINE
    GAUGE: KILOMETERS PER HOUR
    UNITS: KPH
    ->TXD: 00 BC
    ->RXF: 01 00 42 B4 00 00
    ->RXD: 38 0C
    ->MTH: 03 E8 04 00 00 00
    ->NAM: kph
    NOTES: (PRIUS) XX.XX KPH
    GAUGE: GAS PEDAL POSITION
    UNITS: % TOTAL DEPRESSION
    ->TXD: 02 4C
    ->RXF: 01 02 82 44 00 00
    ->RXD: 40 08
    ->NAM: gps
    NOTES: (PRIUS / CAMRY HYBRID) XX.X % DEPRESSION
    GAUGE: TARGET RPM
    UNITS: REVOLUTIONS PER MINUTE
    ->TXD: 03 C0
    ->RXF: 01 03 02 C8 00 00
    ->RXD: 20 10
    ->MTH: 00 01 00 08 00 00
    ->NAM: rpm
    NOTES: (PRIUS) TELLS ENGINE TO REV. PREDICTIVE RPM
    UNITS: % OF TOTAL BATTERY CAPACITY
    ->TXD: 03 C3
    ->RXF: 01 03 82 CB 00 00
    ->RXD: 20 10
    ->NAM: soc
    NOTES: (PRIUS) PASSIVE CA N REQUEST
    GAUGE: BATTERY TEMP (UPPER READ)
    UNITS: DEG C
    ->TXD: 03 C3
    ->RXF: 01 03 02 CB 00 00
    ->RXD: 30 08
    ->NAM: buc
    NOTES: (PRIUS) °C MAX FOR THE 5 MS CYCLE
    GAUGE: BATTERY TEMP (LOWER READ)
    UNITS: DEG C
    ->TXD: 03 C3
    ->RXD: 38 08
    ->NAM: blc
    NOTES: (PRIUS) °C MIN FOR THE 5 MS CYCLE
    UNITS: VOLTS
    ->TXD: 03 C5
    ->RXF: 01 03 02 CD 00 00
    ->RXD: 20 10
    ->NAM: btv
    NOTES: (PRIUS) 3CD PID READING
    GAUGE: EV BUTTON STATUS
    UNITS: BOOLEAN
    ->TXD: 05 21
    ->RXF: 01 05 22 29 00 00
    ->RXD: 31 01
    ->NAM: evb
    NOTES: (PRIUS) EV BUTTON ON OR OFF
    GAUGE: ENGINE COOLANT TEMP
    UNITS: DEG C
    ->TXD: 05 25
    ->RXF: 01 05 82 2C 00 00
    ->RXD: 18 08
    ->NAM: wtc
    NOTES: (PRIUS) XX.X °C
    GAUGE: GAS GAUGE
    UNITS: % FULL THE CURRENT TANK IS
    ->TXD: 05 AC
    ->RXF: 01 05 82 A4 00 00
    ->RXD: 18 08
    ->MTH: 00 64 00 04 00 00
    ->NAM: gas
    NOTES: (PRIUS) XX.X % FULL
    GAUGE: CURRENT AVG. TRIP MPG
    CONF?: YES
    UNITS: MPG
    ->TXD: 00
    ->RXD: 00 00
    ->MTH: 00 00 00 00 00 00
    ->NAM: cfe
    NOTES: CURRENT FE
    GAUGE: DAILY AVG. MPG
    CONF?: YES
    UNITS: MPG
    ->TXD: 01
    ->RXD: 00 00
    ->NAM: dfe
    NOTES: DAILY FE
    GAUGE: Solicited Traction SOC
    CONF?: Yes, confirmed
    UNITS: Percentage of Full charge
    ->TXD: 07 E3 21 CE
    ->RXD: 30 08
    ->NAM: Sts
    NOTES: Solicited / Active gauge, so first char upercase
    GAUGE: Passive Traction SOC
    CONF?: Yes, confirmed on SG FW version "3.15" only not "3.15*"
    ->TXD: 03 C3
    ->RXD: 20 10
    ->NAM: pts
    NOTES: Passive gauge, so first char lowercase
    GAUGE: Solicited L5 SOC
    ->TXD: 07 E3 21 CE
    ->RXF: 05 61 86 CE 09 00
    ->RXD: 30 08
    ->NAM: Sls
    NOTES: Solicited / Active gauge, so first char upercase. RXF is looking for '00' in byte nine. For the traction battery this is the LSB for the battery current which would always (99.61%) read non-zero.
    GAUGE: Passive L5 SOC
    ->TXD: 03 C3
    ->RXF: 01 03 82 CB 08 00
    ->RXD: 20 10
    ->NAM: pls
    NOTES: Passive gauge, so first char lowercase. RXF is looking for '00' in byte eight. For the traction battery this is the temperature reading of the battery. It will only read 0 celcius, when it really is 0 celcius in the battery conpartment.
    GAUGE: WHAT GAUGES DO YOU USE THAT AREN'T LISTED?
    ->TXD:
    ->RXF:
    ->RXD:
    ->MTH:
    ->NAM:
    NOTES:
    DOCUMENTATION
    VEHICLE SPECIFIC CODES
    http://www.scangauge.com/support/pdfs/XGAUGE.pdf
    XGAUGE PROGRAMMING
    http://www.scangauge.com/support/pdfs/XGaugeCoding.pdf
    SGii /w XGAUGE MANUAL
    http://www.scangauge.com/support/pdfs/SGMan5_0.pdf
    OBDii PIDS (WIKIPEDIA)
    http://en.wikipedia.org/wiki/OBD-II_PIDs
    XGAUGES FOR FEH THREAD
    http://www.cleanmpg.com/forums/showthread.php?t=5747
  2. hobbit
    hobbit He who posts articles
    This is great, my only snide comment is that this is something
    that should be maintained at the linear-logic site. Or at the
    very least pointed to from there, so people interested in the
    unit don't have to search all over the place for "street knowledge"
    on this stuff.
    _H*
  3. kmactavi
    I partially agree with that, and I think that Linear Logic has done a fairly good job of documenting Xgauges in the vehicle specific gauges PDF I have linked to. However, we can't really expect them to update this every time one of their users comes up with another gauge. That's why a user maintained list could be more current, and can include gauges that aren't 'officially verified' by Linear Logic. Just to make this clear, this is in no way trying to be an official list, just a thread to point a new user to when they wonder about what XGauges are available. (And for people who are trying to get gauges working)
    Kirk
  4. -mr. bill
    -mr. bill Senior Member
    Curious. I'm wondering if anyone else has monitored both MAF and GPH in a Honda.
    On mine, either there is a huge coincidence of conversions from grams/second of air to deci-gallons per hour of gasoline, OR Honda reports GPH*0.1 for MAF pings. (The only time they diverge is during fuel cut.)
    -mr. bill
  5. Bykerboi
    Bykerboi New Member
    Hello to all; purchased a ScanGaugeII yesterday and looking for programming for an '08 Toyota Matrix
  6. kmactavi
    Hi Bykerboi, welcome to the site!
    I'm pretty sure the Matrix uses CAN protocol, you can check this on the SG after you have it set up. For CAN protocol, the TXD values for the above codes need to be modified, read the XGAUGE PROGRAMMING PDF in the Documentation section above.
    Be sure to check out the links in my signature for driving methods to improve your MPGs.
    Kirk
  7. fanamingo
    fanamingo Well-Known Member
    @kmactavi, thanks for the resource. It's a good idea. You might want to link to XGauge (CAN-bus) for Dummies..., which has a number of XGauges specific to the Prius.
    @-mr. bill, it sounds like you have MAF working as an XGauge. What communication protocol does your car use? My Civic LX uses CANLF, and I can't get any of the XGauges to work.
  8. JusBringIt
    JusBringIt Be Inspired
    hpw works on 99 dodge avenger
  9. kmactavi
    Thanks Fanamingo, it's been added.
    Kirk
  10. mtgeekman
    mtgeekman Well-Known Member
    from a post on the Insight Central forums.
    This is just watching the O2 sensor and dividing the value returned by 2. To get actual voltage coming from the sensor you would need to change MTH to 000100C80000. This will divide the value by 200 (normally you multiply by .005)
    This has been tested on my insight, along with others.
  11. kmactavi
    Thanks mtgeekman, it's been added.
    Kirk
  12. johnuk
    johnuk Member
    Hi All
    i am still playing with the SG11 and need to add some xgauges i cant get my head around all these maths to work it all out ,has enyone got a list for the Ford pwm ones looking for instant MPG, and more if poss, i put some in from the list on this forum Boost and HP seamed to work ok but a few did not but they are for the vw i think,
    hard to get info hear in UK not many people got SG11s yet so no forums yet,
    all help would be great,
    and thanks for a great site,
    john
    2004 ford mondeo 2ltr tdci 130ps.
  13. xcel
    Hi Johnuk:
    ___The iMPG is a std. gauge so you will not need to program that. The X-Gauge aMPG is TXD all 0’s, RXF of 8000 0000 0000, RXD all 0’s and MTH all 0’s if that helps? What else are you looking for exactly?
  14. johnuk
    johnuk Member
    Hi Wayne
    thanks for info, i was just looking for a genaral list so i could look and see what would work for me,but i am not sure the SG11 i have just got is working as it should yet waiting to do my first tank refil, as i said in my first post my MPG is all over the place from 1 to 9999 mpg and enything in between? but will keep playing, not sure if the SG11 in europe is the same as the US one,
    thanks
    john
  15. JusBringIt
    How do I get trip mpg to show as one of the gauges? Tanks for the reply! (and no, I will not be giving away tanks of gas :D)
  16. xcel
    Hi Ricardo:
    ___If you have a 3.15 Firmware equipped ScanGauge (X-Gauge capable), you can create the X-Gauge with the above coding :)
    The X-Gauge aMPG for current trip or segment is TXD all 0’s, RXF of 8000 0000 0000, RXD all 0’s and MTH all 0’s.
  17. JusBringIt
    awesome!!! thanks a lOT!! you are the man!! but wait..you already know that. :)
    and um..you did you mean "below code"..right? ;) just making sure.
  18. xcel
    Hi Ricardo:
    ___I am just another member like the 7,320 members we have currently. Ron of Linear is the man with Carl and Dan the super coders figuring out new and better X-Gauge coding for the betterment of all :)
  19. Dan
    Dan KiloTanked in post 153451
    Here's a dump of some of the gauges I've found for the Prius. Per the notes the "gps" gauge works on the TCH as well. I have a case convention I hold to. Builtin gauges are all caps, Published gages are lowercase with the first char capped, Discovered gauges are all lowercase.
    I've also corrected "Bta" since there is a known error in the previous version. I've also offered up both "Soc" and "soc". Since "Bta" and "Soc" conflict (can't be displayed together), there is a need for non-conflicting versions.
    Also you may want to link to the LL XGauge Coding Manual recently "publicly" released.
    CONF?: YES
    ->TXD: 07 E3 21 CE
    ->RXD: 30 08
    ->NAM: Soc
    NOTES: (PRIUS) %
    UNITS: VOLTS
    ->TXD: 00 33
    ->RXD: 20 10
    ->NAM: Btv
    CONF?: YES
    UNITS: +/- AMPS
    ->TXD: 07 E3 21 CE
    ->RXD: 38 10
    ->NAM: Bta
    ->TXD: 00 38
    ->RXD: 30 08
    ->NAM: bps
    UNITS: DEG C
    ->TXD: 00 31
    ->RXD: 10 08
    ->NAM: etc
    UNITS: KPH
    ->TXD: 00 BC
    ->RXD: 38 0C
    ->NAM: kph
    ->TXD: 02 4C
    ->RXD: 40 08
    ->NAM: gps
    GAUGE: TARGET RPM
    ->TXD: 03 C0
    ->RXD: 20 10
    ->NAM: rpm
    ->TXD: 03 C3
    ->RXD: 20 10
    ->NAM: soc
    UNITS: DEG C
    ->TXD: 03 C3
    ->RXD: 30 08
    ->NAM: buc
    UNITS: DEG C
    ->TXD: 03 C3
    ->RXD: 38 08
    ->NAM: blc
    UNITS: VOLTS
    ->TXD: 03 C5
    ->RXD: 20 10
    ->NAM: btv
    UNITS: BOOLEAN
    ->TXD: 05 21
    ->RXD: 31 01
    ->NAM: evb
    UNITS: DEG C
    ->TXD: 05 25
    ->RXD: 18 08
    ->NAM: wtc
    GAUGE: GAS GAUGE
    ->TXD: 05 AC
    ->RXD: 18 08
    ->NAM: gas
    CONF?: YES
    UNITS: MPG
    ->TXD: 00
    ->RXD: 00 00
    ->NAM: cfe
    NOTES: CURRENT FE
    CONF?: YES
    UNITS: MPG
    ->TXD: 01
    ->RXD: 00 00
    ->NAM: dfe
    NOTES: DAILY FE
    11011011
  20. JusBringIt
    O wow this is quite a bit of info. You guys are amazing. A helping hand from someone in another side of the country. Maybe this can remind americans what america really is. *:tear: keep it up guys!
