Next Prius to go turbo?
Discussion in 'Toyota' started by Sledge, Jun 6, 2006.
  1. Sledge
    Sledge I like owls with captions
    http://www.autoexpress.co.uk/news/68124/prius_to_be_given_turbo_boost.html
  2. AZBrandon
    AZBrandon Guest
    Why in the universe would they go to both a larger engine and forced induction at the same time? Does the Prius really need a 150hp engine? You've got to be kidding me, if anything, turbocharging should be combined with engine downsizing, not upsizing. I would say this article is flat out wrong.
  3. brick
    brick Answers to "that guy."
    A 1.8 litre lean-burn turbo engine to go in their small non-hybrid cars I would believe. It could be that we are really looking at two distinct drivetrains that have been erroneously garbled into one.
    ___I have to believe this “rumor” is in error. Toyota could lean burn the 1.5 w/ a Turbo and receive another 10% vs. the 1.8? Something seems amiss given you do not gain FE by moving up in the displacement ranks. The Prius’ performance comes from HSD, not the very efficient atkinsonized Echo 1.5L ICE. With an even more powerful Li-Ion pack (rumor) and smarter MGSets (rumor of a geared/clutched MG1), I could understand a lean burn capable 1.0 - 1.3 w/ a turbo as a better match for the Prius III then a 1.8? It will be interesting to finally receive the details once they are officially released.
  5. Sledge
    A low pressure turbo tuned right could add several MPG. It's a shame it's not more popular with manufacturers.
    I'd bet we'll see this more often since recently some company whose name I forget has introduced a material that can withstand the heat of a turbo so as to create a variable exhaust vane system to improve turbo performance and efficiency. It first appeared on the Porsche 911 Turbo and I think the Acura RDX mini SUV has it too.
